Montana State CSC Variable J-Pipe
Electronically controlled J-Pipe that varies length based on engine rpm. By: Peter Buckley and Trevor Ness
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Uses a magnetic encoder to measure engine sparks and derive rpm. Data is then sent through an equation to get the wavelength of exhaust gasses. Pipe length is then changed to match 1/2 the wavelength which creates a noise cancelling effect.
