Material for finishing the case:
- Sherwin-Williams Small Correction Putty
- General Purpose Primer (Gray)
- General Purpose Paint (Blue)
I didn't have the SBC yet and used the original Baffa-2 externally (ie the case worked as monitor+keyboard only). In this example, I used the "Baffa-X" set which works like an MSX1.
Now let's start finishing with the primer paint:
