Starting to put the stuff together, turned on the OLED
And have a design in mind it's not what I wanted but trying to keep it small
The bottom picture shows the general flow of the parts eg. dpad -> OLED -> speaker
underneath that is the Pi 4B, then the two stepper boards oriented 90 degrees
I'm keeping all the ports open and not soldering anything to the Pi 4B so it's not stuck in this project
Although once together I probably would not take it apart
I want to get the case done by the end of this weekend... will see because it's a bit of design work (spacing) and print time (if I get it right first try or two).
Mostly I don't want a box of parts anymore, so I want to speed up the physical assembly and then can dial in the software over time
I still have to write the code for the dpad, speakers and other stuff... and more but making progress.
This was the old design/thought I had.
speaker on left
