Unfortunately the split 18650-cell holders are not tight enough so the battery can slip out hence zip tie. A more long-term solution is a clip/sandwich deal with screws.
What I'll do here is keep one of the zip ties and use a bread tie to keep them down (pos side).
Here's the body layout. I'm working on the shell design.
