![](https://cdn.hackaday.io/images/1312111674943470150.jpg)
This one did the best of all of them. Depending on wind direction, but much less so, it managed the best spreading of smoke. There is always going to be a need to carefully level it & block wind. Longer cylinders might improve it. The mane problem is the metal gets super hot. It might have to be ceramic.
![](https://cdn.hackaday.io/images/875351674948325666.jpg)
A longer, narrower exhaust pipe made it diffuse evenly in more wind, but it was still sensitive to leveling.
![](https://cdn.hackaday.io/images/5674051674948325787.jpg)
The 20mm diameter melted as expected, despite being made of PETG. Creating a ceramic hot plate is the great task.
A bigger diameter than 36mm could make it heat resistant.
