SD card Pinout
- DATA3
- CMD
- VSS1
- VDD
- CLK
- VSS2
- DATA0
- DATA1
- DATA2
eMMC Pinout
A3. DATA0
A4. DATA1
A5. DATA2
B2. DATA3
M5. CMD
M6, CLK
the trick bit now is the connection of the power lines and provide supply decoupling. Thankfully I can remove caps from the original board and the plan is to solder them directly to the power pins of the eMMC chip. This is going to be ugly but it only needs to work long enough to extract the data.
Saabman
