11Color Change
- You can change the colors in the code, I used this simple color picker and copied the RGB color values into the code.
colorWipe(strip.Color(255, 0, 0), 10); // Red (Device 1) colorWipe(strip.Color(255, 255, 0), 10); // Yellow (Device 2) colorWipe(strip.Color(0, 255, 0), 10); // Green (Device 3) colorWipe(strip.Color(255, 0, 255), 10); // Pink (Device 4) colorWipe(strip.Color(0, 0, 255), 10); // Blue (Device 5)
12Charging
- You can directly charge the battery though ESP32-C3 Modules Type C, since this module have on board charging and overcarge protection feture.
I hope you have fun making this project.
Thank You!
