The IR sensor was from time to time blinded by sun...
I simply replaced it by a hall effect switch.
I choosed a 3.3V chip with the reference SS49E
![](https://cdn.hackaday.io/images/6771691686905320580.jpg)
To connect it to the PCB and replace the IR sensor, follow these guidelines
- short R3 with a copper wire
- unsolder R4
- connect the sensor as follows
![](https://cdn.hackaday.io/images/7011341686905445040.jpg)
![](https://cdn.hackaday.io/images/8481391686905467142.jpg)
Then replace the 3D printed "wheel" by the magnet holder. You will need to glue a "diametrical magnet 6mm diameter, 2mm width"
![](https://cdn.hackaday.io/images/896261686906127554.jpg)
Note that the 4mm nut is hidden into the printed part (add a filament change on top of the nut)
![](https://cdn.hackaday.io/images/8819641686905838817.jpg)
![](https://cdn.hackaday.io/images/5285441686905938740.jpg)
When finished the hall sensor should fly 2 to 3mm above the magnet
![](https://cdn.hackaday.io/images/1377461686905987762.jpg)
The code of the project remains strictly the same and is still available on my github page
