The box for Simon game is designed to be laser cut from 3.2 mm thick plywood.
- Red line marks laser cuts.
- Green areas should be engraved to the depth of approx. 0.5 mm.
- Cyan areas should be engraved to the depth of approx. 1.4 mm.
- Blue areas should be engraved to the depth of 2.3 mm (M3 nut height).
Bottom wall is removable and fixed by four M3 × 16 mm countersink screws.
The M3 nuts are set in the top wall which is glued to four side walls.
Four small L-shaped parts should be glued to the inner corners of the box (to reinforce the plywood under the nuts).
Small cross-shaped parts should be glued to the bottom wall under four button switches.
Files for laser cutter are in the download section.
