1 - Battery 1 - Battery Holder 4 - Flat Top RGB LED 4 - Red Wires 4 - Blue Wires 2 - Wood Screws 1 - Ornament
2
Screw screws into holes
Give each screw about 3 twists. You don't want them falling out but you want to keep enough room to wrap wires around them.
3
Place LEDs
Match the flat side of the LED to the flat side of the engraving. Alternatively you can also match the long and short legs to the flat side of the engraving. Long legs are positive and short legs are negative. The flat side marks the negative on the engraving so match the short leg to the flat side. Once all LEDs are in place, flip the board over.
Bend LED legs one going down and one going up (make sure to keep bending consistent on each LED (if you bend the negative leg down and the positive up repeat for all LEDS)
