[10 Feb 23] (Edits: 25 Oct 2023)
Just like every other project code, code gd0140 isn't just a set of 4 random numbers. It means there's 139 project-class tasks I've also got to do that came before it. I loosely defined a project as something that would take >2 hours and has multiple standard tasks within it, but I'm considering changing this to something that's actually project-esque.
This is the OneNote system I've got now, which I just call "Whiteboard" because I used to write all my tasks on a physical whiteboard:
The issue is resistance. Because it's somewhat tedious to open OneNote, then navigate to the relevant section and then add dates and tags, this system I have is underutilized. The reason my tasks are currently OneNote is because it was tedious to get the correct whiteboard pen colour and squeeze yet another task into a small space, and then manually rub out tasks when they were done.
Ever since the manual whiteboard solution, probably over 5 years ago, I've wanted to write a program that automatically does what I'm manually doing now in OneNote. I'd then want to create roadmaps or Gantt charts, as well as transmit task information to #Interval Provisional [gd0097] so that I can further track tasks that were attempted but not finished.
That's actually the main thing I want really: being able to go into my ToDo app at the end of the day and checkmark that I've attempted a task but the task itself is still unfinished. Take "Find PTFE for seal" as an example task. It's not a task I could further split into a subtask, and it might take 2 or 3 days to dig through AliExpress to actually find a seal, but only knowing that the seal was found on some date isn't helpful for Me In The Future trying to better understand / estimate how long a task would take, nor does it feel fufilling for me on the days when I put effort towards the task without much to show for it.
I think I really have to just sit down and actually make meaningful steps towards a better system, because the absolute first project(s) in my brand-new-at-the-time OneNote system was to add all the tasks and projects I had in my mind.
I've gone with the name TasGlass for now because it sounds resistanceless / clear / transparent, it's smoother to say than "Task Glass", it rhymes and I kind of like to think of it as "Tool Assisted Speedrun Glass". Now that I mention it, I'm now also considering Task% or Tas%, referring to "any%" speedruns. Task% looks nicer in type but "Taspercent" is much more fluid to say, even more than TasGlass actually.
[14 Feb 23]
It's likely that Task% and IntProv (#Interval Provisional [gd0097]) would actually be bundled together, just like Microsoft's "Mail and Calendar" Windows 10 app. The planning data from Task% helps set up work blocks for IntProv and the analytical data generated from IntProv is very desirable for Task%.
[25 Oct 23 Edit] - I just added the paragraph about tasks that were attempted being a main feature, so TaskAttempt might be an idea.
