In order to make any more than a cube fit, the memory mapping gets gnarly. A big deal in the old days was locating programs around the bitmaps. The default output from ld65 starts the executable at $800. The bitmaps go from $2000 to $7b40. Then $8000 to $d000 is free.
You can dump the memory in VICE by entering the monitor (alt-h). Type 'm 0 ffff' to dump the entire memory. You can make a kind of debugging trace by setting an address & printing the address with 'm 2000' Type 'r' to dump the registers.
CC65 has ways of creating memory holes but they're quite involved & specific to C. The easiest way in assembly was just reserving a hole & jumping past it:
jmp mane
.res $7700
mane:
Another way is moving the bitmaps higher. There are all kinds of restrictions on where color memory & bitmap memory can be. The mane one is a bitmap can't span 2 VIC banks. The highest useful bitmap is $a000 so by moving the bitmaps to $5c00 to $c000 it had 20kb for the program. Anything higher overlaps the I/O registers or kernal. Cc65 automatically swaps out the BASIC ROM but it uses the kernal.
![](https://cdn.hackaday.io/images/3170941676957409205.png)
After freeing up enough memory, the procedural gear was drawing at roughly 2 frames per second.
