The single bay version of the 3D printable NAS is completed. The models are uploaded to the file section of this project as "single_bay_final.zip".
If you want one for some reason (maybe you want a single 10TB HDD instead of two 4TB one?) , you can use this version instead.
All the components required for the electronics are identical to the 2 bay version, except you can choose to not solder one of the 12V buck converter as well as the 2nd bay's SATA adapter. Take a look at the model files and you will know how to work on it.
