The LCD analysis isn't strictly complete. While I'm pretty sure I found the data lines (nybble mode, PD5-2), there are control lines as well.
While rummaging through the RAM stuff, I came across a routine:
F618 sub_F618:
F618 86 01 ldaa #1
F61A BD F6 5E jsr sub_F65E
F61D 39 rts
which then invokes:
F65E sub_F65E:
F65E 15 5B 02 bclr byte_5B 2
F661 16 tab
F662 BD F6 74 jsr sendLCDbyteB_F674 ; send byte in B to LCD (w/ctrl as per 0x5b)
F665 14 5B 02 bset byte_5B 2
F668 39 rts
before going off to the 'sendLCDbytesB' routine at F674 that I had already reversed. There were some unknowns in that, namely the data location at 0x5B.
I know that the LCD command for "Clear Display and Set Cursor to loc 0" is 0x01, but being a command, it requires that the control lines OC1 and OC2 be set in a particular state. As per doc, here's how they work:
OC2 OC1 function
0 0 command
0 1 display address
1 0 data
1 1 cursor address
The thing that's interesting here is that we are manipulating byte_5b, which is internal RAM, not a peripheral port. Surely this cannot be memory-mapped. However, revisiting sendLCDbyteB_F674, and the internal routine F68F, it became clear that loc 0x5b stores a virtual copy of those control bits, which then are transferred to harware when writing out the nybble.
F68F sendLCDnybble_F68F:
F68F 4F clra ; (an elaborate way of A = (0x5b) & 3. Why? unknown.)
F690 13 5B 02 04 brclr byte_5B 2 cont_F698 ; LCD control lines state in b1 = IOC2, b0 = IOC1
F694 8A 02 oraa #2
F696 20 00 bra *+2 ; delay 3 cy; 1.5 usec
F698 cont_F698:
F698 13 5B 01 04 brclr byte_5B 1 cont_F6A0 ; LCD control lines state in b1 = IOC2, b0 = IOC1
F69C 8A 01 oraa #1
F69E 20 00 bra *+2 ; delay 3 cy; 1.5 usec
F6A0 cont_F6A0:
F6A0 58 aslb ; move up two bits to align lower nybble with PDb5-4
F6A1 58 aslb
F6A2 B7 80 00 staa $8000 ; XXX mystery?
F6A5 96 08 ldaa PORTD_8 ; PORTD:
F6A7 84 03 anda #3 ; preserve lower two bits
F6A9 1B aba ; merge on shifted B into nybble position (port D7,6 are not bonded, so who cares about those)
F6AA 97 08 staa PORTD_8 ; write nybble out
F6AC 14 00 80 bset PORTA_0 $80 ; 'Ç' ; flick PA7 high, low
F6AF 15 00 80 bclr PORTA_0 $80 ; 'Ç'
F6B2 39 rts
So, the nybble to send is in B, it is shifted up to positions to get to Port D bits 5-2, and location 0x5b is translated into the two bits at Port D bits 1 and 0. Those are merged together and written out to Port D. PAb7 is then flicked high/low. This almost certainly means that PAb7 is the LCD 'EX' line as per timing diagrams.
This also means that Port D is fully accounted for as for its pins (b7,6 are not available on this 40 pin DIP), unless they do double duty somehow. It's interesting that Port D is configured for open-drain outputs, though in the photo you can clearly see a resistor pack next to where Port D is on the package, so those are doubtlessly pull-ups.
Knowing this, these actions at the start of lcdInit make now sense:
EC16 lcdInit_EC16:
EC16 15 5B 01 bclr byte_5B 1 ; IOC1, 2 low for 'command'
EC19 15 5B 02 bclr byte_5B 2
Studying other use cases and correlating with datasheet show that 0x5b bit 1 is IOC2 and bit 0 is IOC2, and that these eventually set PDb1,0.
Another mystery is starting to come to light. The mystery of '8000h'. I have seen several writes to this location of values 0, ffh, 4. (Maybe there are others.) Now that I am pretty sure RAM is at 0100-7fff, then what are these writes (and there is a similar one at C000)? So, maybe memory mapped IO? There is an apparently LCD related routine at EC45:
EC45 sub_EC45:
EC45 86 03 ldaa #3
EC47 97 09 staa DDRD_9 ; DDRD: b1, b0 output; others input
EC49 86 04 ldaa #4
EC4B B7 80 00 staa $8000
EC4E 14 00 80 bset PORTA_0 $80 ; PORTA: b7 high
EC51 96 08 ldaa PORTD_8 ; PORTD: all data bits
EC53 15 00 80 bclr PORTA_0 $80 ; PORTA: b7 low
EC56 14 09 FF bset DDRD_9 $FF ; DDRD: all pins output
EC59 7F 80 00 clr $8000
EC5C 15 08 3C bclr PORTD_8 $3C ; PORTD: b5,4,3,2 low
EC5F 39 rts
It's rarely used: once in 'lcdInit_EC16' and twice in success in 'sendLCDbyteB_F674'. In both cases immediately afterwards bit 5 is tested, and looping happens if it set until it goes low. This bit happens to coincide with the 'BUSY' bit of the LCD status. So I am concluding that sub_EC45 is 'readLCDnybble_EC45'. I do not know 8000 for a fact, but being as it sets bit 2, and this is the only place that the LCD is read from, I am starting to suspect that 8000 is a latch, and bit 2 is wired to the LCD R/~W line (and maybe other things!).
So, on-chip port hardware is so far mapping out like this:
Port A:
b7 LCD EX
b6 (not bonded on DIP40)
b5 RAM Bank Select 1 (A16)
b4 (not bonded on DIP40)
b3 RAM Bank Select 0 (A15)
b2 ???
b1 ???
b0 ???
Port D:
b7 (not available with external memory)
b6 (not available with external memory)
b5 LCD data 7
b4 LCD data 6
b3 LCD data 5
b2 LCD data 4
b1 LCD OC2
b0 LCD OC1
Port B, C -- (used for external memory address/data bus)
There's still the possibility of multiple duty for these lines, but these applications at least I think I am pretty confident of.
A pending mystery is the emulated keyboard ports. There are three lines on A unaccounted for, and maybe they're involved with that, but a peculiarity of Port A on this device is that bit 2,1,0 are hard configured in silicon as inputs only. 3 and 7 are bidirectional, but are here configured as outputs (and 5 is hard configured as output). There almost surely needs to be some other output line for keyboard data, so there's more mysteries to solve there, eventually.
Update labels, comments, and propagate....
