While making a clean-up pass (of resolving addresses), I came across a routine at 0xF5ED that prints the message "Attached to Mac, emulating keyboard." or "Attached to PC, emulating keyboard.". Which message is governed by bit 0 in loc 0x008a. I should be able to trace cross references into this function, and to that memory location, to help map out the keyboard emulation code.
Also, creating a data segment for special function registers (SFR) and internal RAM (IRAM)
Tired of scrolling through the datasheet to figure out SFR addresses, I added a data segment 0x0000-0x003f and spent a little time labelling those locations. This is tedious, but it helps a lot because the symbolic names then propagate through the disassembly. Ultimately, I needed to do this for the the IRAM data anyway (and also the external RAM once I figure out where it is mapped), so might as well get started.
0000 ?? PORTA_0: rmb 1
0001 ?? rmb 1 ; (reserved)
0002 ?? PIOC_2: rmb 1
0003 ?? PORTC_3: rmb 1
0004 ?? PORTB_4: rmb 1
0005 ?? rmb 1 ; (reserved)
0006 ?? DDRB_6: rmb 1
0007 ?? DDRC_7: rmb 1
0008 ?? PORTD_8: rmb 1
0009 ?? DDRD_9: rmb 1
000A ?? rmb 1 ; (reserved)
000B ?? CFORC_B: rmb 1
000C ?? OC1M_C: rmb 1
000D ?? OC1D_D: rmb 1
000E ?? ?? TCNT_E: rmb 2
0010 ?? ?? TIC1_10: rmb 2
0012 ?? ?? TIC2_12: rmb 2
0014 ?? ?? TIC3_14: rmb 2
0016 ?? ?? TOC1_16: rmb 2
0018 ?? ?? TOC2_18: rmb 2
001A ?? ?? TOC3_1A: rmb 2
001C ?? ?? TOC4_1C: rmb 2
001E ?? ?? TI4O5_1E: rmb 2
0020 ?? TCTL1_20: rmb 1
0021 ?? TCTL2_21: rmb 1
0022 ?? TMSK1_22: rmb 1
0023 ?? TFLG1_23: rmb 1
0024 ?? TMSK2_24: rmb 1
0025 ?? TFLG2_25: rmb 1
0026 ?? PACTL_26: rmb 1
0027 ?? PACNT_27: rmb 1
0028 ?? SPCR_28: rmb 1
0029 ?? SPSR_29: rmb 1
002A ?? SPDR_2A: rmb 1
002B ?? BAUD_2B: rmb 1
002C ?? SCCR1_2C: rmb 1
002D ?? SCCR2_2D: rmb 1
002E ?? SCSR_2E: rmb 1
002F ?? SCDR_2F: rmb 1
0030 ?? ?? ?? ??+ rmb 9 ; (reserved)
0039 ?? OPTION_39: rmb 1
003A ?? COPRST_3A: rmb 1
003B ?? PPROG_2B: rmb 1
003C ?? HPRIO_3C: rmb 1
003D ?? INIT_3D: rmb 1
003E ?? TEST_3E: rmb 1
003F ?? CONFIG_3F: rmb 1
Soon I'll start posting the full disassembly for the curious in the files area, but right now I'm moving so fast that it would be wildly out-of-date at any moment.
