While whizzing through the code I did notice some text:
FCBB 20 20 20 20+aLowBattery: fcc " Low Battery!!"
FCBB 20 20 20 20+ fcb 0
referenced at
E514 showLowBattery_E514:
E514 BD F6 18 jsr clearHomeLCD_F618 ; Clear LCD set cursor pos 0
E517 BD F7 4E jsr setcpLine1_F74E ; set cursor Line 1
E51A CE FC BB ldx #aLowBattery ; " Low Battery!!"
E51D BD F6 69 jsr showText_F669 ; show nts text @ X
E520 39 rts
in turn referenced at
E503 sub_E503:
E503 12 00 02 0C brset PORTA_0 2 locret_E513 ; leave if PORTA b2 high
E507 BD E5 14 jsr showLowBattery_E514 ; XXX low-battery related
E50A CE 00 04 ldx #4 ; about 1.96 sec
E50D loop_E50D:
E50D BD F6 1E jsr delay590ms_F61E ; delay ~ 590 ms
E510 09 dex
E511 26 FA bne loop_E50D
E513 locret_E513:
E513 39 rts
in turn referenced early in 'start' at
E02E BD E5 03 jsr sub_E503 ; XXX check low battery and show message if needed
The code at E503 is interesting because the whole 'show the low battery message' is only executed if Port A, bit 1 is low. Otherwise it is skipped.
So I conclude that PAb1 is the 'battery OK' indicator. Looking at the board photo, there is clearly a power section to the right, and in particular this device:
This is a DC-DC converter, and makes since because two AA batteries at nominally 3V is not going to power the 5V system. So it steps up. However, in the datasheet (and I love the '70's disco font used for the section headings), there is a reference circuit on p. 11 for a low-battery indicator, so I suspect that pin 6, A0, of this device is connected to PAb1 of the CPU. (Maybe with some interceding circuitry, but at least logically so.)
