While whizzing through the keyboard stuff, there is some special handling of some keystrokes. This is by scan code, so it's difficult for me to puzzle out what they are. One exception, though, is for setting the 'send speed'. There is menu text showing the current speed and allowing changing the speed.
F034 changeSendSpeed_F034:
F034 BD F6 18 jsr clearHomeLCD_F618 ; Clear LCD set cursor pos 0
F037 CE FD 76 ldx #aToChangeSendSp ; "To change Send speed, type 1, 2, 3 or 4"...
F03A BD F6 69 jsr showText_F669 ; show nts text @ X
F03D BD F7 4E jsr setcpLine1_F74E ; set cursor Line 1
F040 CE FD 9F ldx #a1VerySlow2Slow ; " 1: VERY Slow 2: Slow"
F043 BD F6 69 jsr showText_F669 ; show nts text @ X
F046 BD F7 54 jsr setcpLine2_F754 ; set cursor Line 2
F049 CE FD BF ldx #a3FastDefault4F ; " 3: Fast(default) 4: Fastest"
F04C BD F6 69 jsr showText_F669 ; show nts text @ X
F04F BD F7 5A jsr setcpLine3_F75A ; set cursor Line 3
F052 CE FD E2 ldx #aCurrentSetting ; "Current setting is "
F055 BD F6 69 jsr showText_F669 ; show nts text @ X
F058 B6 01 5C ldaa kbdemuSpeed_15C ; XXX keyboard transfer speed (0, 1, 2, c8???)
F05B 81 00 cmpa #0 ; 0 is very slow
F05D 26 04 bne cont_F063
F05F C6 31 ldab #'1'
F061 20 16 bra showcurspeed_F079
F063 cont_F063:
F063 81 01 cmpa #1 ; 1 is slow
F065 26 04 bne cont_F06B
F067 C6 32 ldab #'2'
F069 20 0E bra showcurspeed_F079
F06B cont_F06B:
F06B 81 02 cmpa #2 ; 2 is fast
F06D 26 04 bne cont_F073
F06F C6 33 ldab #'3'
F071 20 06 bra showcurspeed_F079
F073 cont_F073:
F073 81 C8 cmpa #$C8 ; '+' ; c8 is fastest
F075 26 19 bne loc_F090 ; unknown setting, force to 1, slow
F077 C6 34 ldab #'4'
F079 showcurspeed_F079:
F079 BD F6 74 jsr sendLCDbyteB_F674 ; send byte in B to LCD (w/ctrl as per 0x5b)
F07C waitKey_F07C:
F07C BD E5 A0 jsr scanKbd_E5A0 ; do key scan and enqueue
F07F BD EB EE jsr dequeueKbdScanCode_EBEE ; pull scan code A (rowno|colno) from keyboard buffer; V set if empty, clear if valid
F082 29 F8 bvs waitKey_F07C
F084 81 5E cmpa #$5E ; scan code for '1'
F086 26 04 bne cont_F08C
F088 86 00 ldaa #0
F08A 20 18 bra storeSpeed_F0A4
F08C cont_F08C:
F08C 81 5D cmpa #$5D ; scan code for '2'
F08E 26 04 bne cont_F094
F090 loc_F090:
F090 86 01 ldaa #1
F092 20 10 bra storeSpeed_F0A4
F094 cont_F094:
F094 81 5C cmpa #$5C ; scan code for '3'
F096 26 04 bne cont_F09C
F098 86 02 ldaa #2
F09A 20 08 bra storeSpeed_F0A4
F09C cont_F09C:
F09C 81 51 cmpa #$51 ; scan code for '4'
F09E 26 07 bne leave_F0A7
F0A0 86 C8 ldaa #$C8 ; '+'
F0A2 20 00 bra *+2
F0A4 storeSpeed_F0A4:
F0A4 B7 01 5C staa kbdemuSpeed_15C ; XXX keyboard transfer speed (0, 1, 2, c8???)
F0A7 leave_F0A7:
F0A7 39 rts
Most of this is simply emitting text, translating a setting value to a textual equivalent for presentation, and waiting for a keystroke to change the value. I am pretty sure that loc_15C is the current keyboard emulation speed, since it drives the text for the current setting and is updated when we change it. So I renamed it to kbdemuSpeed_15C.
Since in this limited case we have well-know keys that are switched on in a understandable way, we can learn at least a few key scan codes for '1' - '4'.
It's a curiosity as to why the setting value is 0, 1, 2, and 0xc8 (???). Maybe that will make sense later.
This routine is called from the keyboard handler at EE18:
EE08 loc_EE08:
EE08 81 56 cmpa #$56
EE0A 27 25 beq loc_EE31
EE0C 81 21 cmpa #$21
EE0E 27 0E beq loc_EE1E
EE10 81 61 cmpa #$61
EE12 27 17 beq loc_EE2B
EE14 81 4D cmpa #$4D ; scan code for 'S'
EE16 26 27 bne loc_EE3F
EE18 BD F0 34 jsr changeSendSpeed_F034
EE1B 7E EE DA jmp loc_EEDA
and since the manual states that option-clover-S is the sequence to get into the speed menu, we can infer that 0x4D is likely the scan code for 'S'.
