It's probably worthwhile to summarize what hardware aspects I have gleaned thus far.
Port A:
b7 LCD EX
b6 (not bonded on DIP40)
b5 RAM Bank Select 1 (A16)
b4 (not bonded on DIP40)
b3 RAM Bank Select 0 (A15)
b2 ???
b1 Low Battery
b0 ???
Port D:
b7 (not available with external memory)
b6 (not available with external memory)
b5 LCD data 7
b4 LCD data 6
b3 LCD data 5
b2 LCD data 4
b1 ???
b0 ???
Port B, C -- (used for external memory address/data bus)
8000 write: Keyboard columns
8000 read: Keyboard rows
C000 write: Keyboard columns
8000 write: b2 - LCD R/~W
b1 - LCD OC2
b0 - LCD OC1
Inferred Key ScanCodes:
The keyboard scan code is 8-bits, with high nybble being row number, and low nybble being column number. The firmware largely works with scan codes directly. This is a bit tricky to figure out the key matrix from software alone. A few can be figured out because they correlate to prompts indicating what key is expected to be pressed.
0x22 'y' as per prompt y/n @ EF20
0x5e '1' as per prompt 'send speed' @ F084
0x5d '2' ...
0x5c '3' ...
0x51 '4' ...
0x56 'Clear File' as per 'handleKeyScanCode' @ EE08
0x4d 's' as per change send speed at @ EE14
