Memory displays
A project log for Aloidia: wireless split solar powered keyboard
Aloidia is a staggered, split, fully wireless solar-powered mechanical keyboard with extremely long battery life.
nguyen-vincentNguyen Vincent • 03/02/2023 at 09:47•0 Comments
Currently, the memory displays can give information about connection status as well as battery level. I've chosen an icon as the battery level but it is also possible to have the percentage displayed. A very slight issue with the current setup is that the LDO powering the display discharges itself very slowly when its enable pin is low (TPS7A0333DBVR). The next iteration will use the P-version of that same LDO (TPS7A0333PDBVR) which has active discharge when disabled.
