I almost solved the problem with "jumpy" values.
A SW low pass filter is applied on the min readings of 100 samples (which should catch 2 full cycles i.e. 2 intakes).
Now the values shown are a lot more stable and the throttle bodies can be synchronized by slowly turning the dedicated screws.
Hey, virtual high-five on that! Carb sync is touchy, it sort of sounds like you're "there" as far as making it useable.
Thanks to your suggestions!
