Just to be sure that the ALU of the system will work, I simulated it using a little freeware program named "Digital". Yes, I simulated it using Logic World, but a second simualtion seems to be a good idea. And it worked perfect with 4 bit:
Here you see 1 bit of the ALU:
And 4 of the 1 bit ALUs connected together:
