This is a adress multiplexer, with this module the adressbus-register can be loaded either by the program-counter or by the adress-register. The selection is done by an input signal and is showed by a blue LED.
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
