ALU tested and the system is adding the numbers from 1 to 100
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
peterPeter 08/28/2024 at 19:180 Comments
The following video shows the addition of the numbers from 1 to 100 in 29 seconds, with the result of 5050 stored in the accumulator afterward.
And here you see the result after the programm:
5050 = 0001 0011 1011 1010
