Very strange result
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
peterPeter 09/20/2025 at 19:230 Comments
After analyzing the timing of the system I optimized the timing of the memory module and the clock system and started the system test. Did not work. I started again, same result. Then I changed both timing back to the unoptimized situation and this was the result:
Thats really strange...
