So, the tests of the implementation of the branch command are successful. Dependent on the branch signal (which later will be set by the ALU) the PC was set by the +1 adder or by the value from the databus.
The next steps are the implementation of a memory emulator using a arduino (with relay cards) and finishing the adress module of the relay CPU
