Combine two command modules...
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
peterPeter 07/01/2024 at 18:570 Comments
A more detailed analysis shows that the two command modules for the instructions 'Load accumulator with content from address X' and 'Store accumulator in address X' differ in only one of the six steps. Therefore, the two modules can be combined, with only step 4 needing to be divided between two relays:
In LDAM micro-command 2 is switched on, in STAM it is microcommand 6. That is the only difference.
