Finished a little module...
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
peterPeter 07/16/2024 at 05:100 Comments
So, the following little module ist part of the ALU and the branch logic. This module checks if value stored in the Accumulator is Zero, Even or negative (if the value is stored as a two's complement value).
