So, I have now dismantled the system to be able to measure more accurately. And as I suspected, unfortunately, there is a connection between Data Bus[3] and Data Bus[4].
No problem between DB[2] and DB[3].
Connection between DB[3] and DB[4].
And to be honest, the solder joint is not my best work:
