Funny problem...
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
peterPeter 10/30/2024 at 21:330 Comments
I tried a new program. I wanted to multiply 3 pairs of numbers and add the results...perfect for using the CALL and RETURN functions. But the end-result was not correct. I analyzed videos of the runs (by checking the LEDs), I also tried the three multiplications and the addition of three results in seperate programs...everything was fine. I think that the three multiplications are influencing each other...but before I step deeper into the problem I write a program which is testing the complete hardware of the system, especially the ALU, to be sure that a program error is the reason of the little problem.
