To ensure that repeated test runs of the system do not lead to a relay failure (relays are mechanical components and do not have unlimited durability), I have now started a durability test of two relays. An Arduino switches on and off 50 times per second, using a transistor to control a relay. This relay, in turn, switches a second one. I will let this setup run until one of the relays fails.
