So, I started to calculate a SQRT approximation (the SQRT(6000) = 244 instead of 244,9489742...).
The first draft of the software was able to calculate SQRT(26) = 5, but SQRT(60000) was wrong. Together with ChatGPT we analyzed the code and we found the problem.
To compare two unsigned 16 bit numbers in a 16 bit machine without a CMP command is not easy...my first draft was this...and is wrong:
// -------------- Now check quadrat > n , quadrat == n or quadrat <= n -------
// Check if quadrat > 1000 0000 *************
daten[46] = 0x4010; // BN
daten[47] = 56; // quadrat >= 1000 0000
// quadrat < 1000 0000 *********************
daten[48] = 0x1800; // LDAM
daten[49] = 3; // n
daten[50] = 0x4010; // BN
daten[51] = 54; // n >= 1000 0000
daten[52] = 0x4000; //BA
daten[53] = 60; // Compare n and quadrat
daten[54] = 0x4000; //BA
daten[55] = 92; // Quadrat < n
// quadrat >= 1000 0000 *****************
daten[56] = 0x1800; // LDAM
daten[57] = 3; // n
daten[58] = 0x4010; // BN
daten[59] = 82; // n < quadrat, else: compare
// Compare n and quadrat, n in accu
daten[60] = 0x3540; //NOT
daten[61] = 0;
daten[62] = 0x3440; //ADD
daten[63] = 0x0001;
daten[64] = 0x2800; // STAM
daten[65] = 69; // ADD for compare
daten[66] = 0x1800; // LDAM
daten[67] = 8; // quadrat
daten[68] = 0x3440; //ADD
daten[69] = 0x0001;
daten[70] = 0x4018; // BZ
daten[71] = 76; // quadrat == n
daten[72] = 0x4010; // BN
daten[73] = 92; // n > quadrat
daten[74] = 0x4000; //BA
daten[75] = 82; // quadrat > n
You see, I use BN (to check the MSB) and make a distinction between greater/smaller 8000 0000. Looks funny and is wrong.
The new compare looks that way, much, much better:
daten[46] = 0x1800; // LDAM n
daten[47] = 3; // b bei daten[101]
daten[48] = 0x3540; // NOT A ; A = ~b
daten[49] = 0;
daten[50] = 0x2800; // STAM 9 ; daten[9] = ~b
daten[51] = 57;
daten[52] = 0x1800; // LDAM a ; A = a
daten[53] = 8; // a bei daten[100]
daten[54] = 0x3440; // ADD 1 ; A = a – b
daten[55] = 1;
daten[56] = 0x3440; // ADD [n] ; A = a + (~b)
daten[57] = 1; // wird von STAM(9) mit ~b ersetzt
daten[58] = 0x4018; // BZ → 300 ; if A==0 ⇒ a==b
daten[59] = 76;
daten[60] = 0x4008; // BC → 100 ; if Carry ⇒ a>b
daten[61] = 82;
daten[62] = 0x4000; // BA → 200 ; else a<b
daten[63] = 92;
The idea from ChatGPT was to use BC instead of BN...and worked.
In my C# simulation of the relay CPU (very useful) the new program works fine, so I will prepare a new video.
Peter
