The first "Hello world"
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
peterPeter 07/31/2025 at 06:191 Comment
Now I changed my strategy to connect a display to the relay CPU...because of the problems switching the E-input using a relay.
Instead of connecting the relay world and the display directly, using an arduino as a communication system between the display and the relay world will be the solution. All control lines, including RS and E, are set by the relay I/O register and read by the arduino. Then the arduino is setting the lines to the display.
That is how the test system looked like:
And ... may be it will work:
Paul McClay wrote 08/01/2025 at 01:55 point
Hello_Homebrew 16 bit relay computer
