Since the stability of the system shows some weaknesses and several parameters of the clock as well as of the memory were estimated rather than determined through analysis, the quality of the system will now be gradually improved:
This are the teststeps:
Tests of the Control Unit (including Logic Analyzer):
Phase 1:
First: check whether adding a capacitor to the relay makes a difference
Add capacitors to the clock relays, check them with the oscilloscope
Add pull-down resistors to the clock relays, check with the oscilloscope
Add capacitors and resistors to the memory outputs
Check the memory relays on the oscilloscope like the clock relays
Simulate read and write cycles with Arduino and check the memory’s response on the oscilloscope
Let the relay system run for a while
Consider: adding capacitors and pull-downs to the control lines of the control unit
Phase 2:
Connect the control unit directly with NOP as the instruction on the data bus and run at maximum speed. For this, have the memory-Arduino output NOP fixed on the data bus
Now do the same with all other instructions
Feed the control unit directly with NOP, but this time from memory. Again, test at maximum speed
Do the same with the other instructions, but without connecting write…so nothing will be written
Also connect write…and have the Arduino output successful writes on the console. (For this test, connect the ALU and write a value into the accumulator)
Check all control lines on the oscilloscope
Tests of the Address Unit (requires successful Control Unit tests):
Phase 1 (standalone tests):
Arduino supplies the address unit with signals to increment the PC, determine maximum speed
Also check the address output on the address bus
Test the process of loading an address via the data bus
Check the stack register
Phase 2 (test with Control Unit):
Fetch NOP instruction from memory and let PC run in parallel
Fetch NOP instruction from memory including addresses
Run a loop. Determine maximum frequency
Tests of the Arithmetic Unit:
Accumulator always plus 1, determine maximum speed (control and address units already tested)
Same with the other logic elements, again determine maximum speed
Check branch conditions
Check carry
Peter
