FPGA Core calculates square root
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
peterPeter 11/17/2025 at 07:012 Comments
The following picture shows the result of calculating the integer square root of 60,000: 244 (1111 0100 in binary), computed by a relay CPU core implemented in an FPGA. The program running on the FPGA is the same as the one used on the relay CPU.
The FPGA will now be connected to the I/O register of the relay system and used as a mathematical coprocessor.
Peter wrote 11/19/2025 at 05:41 point
Hi, you can download the VHDL Code in the download-area of my project page: RelCPUSQRT.zip. Best regards
Bertrand Selva wrote 11/17/2025 at 19:04 point
Bravo on this impressive projet.
It’s a great idea to use an FPGA as the digital counterpart of the relay computer.
Do you plan to use it as an emulator for the relay CPU, or as a true coprocessor attached to the system’s I/O?
If possible, I’d be interested in the HLV code, could you share it?*
