2x ADS131M08, ESP32-C3, STM32F103C8/GD32VF103CB/CH32V103C8
ALPHA1.0 TEST FAILED,
electrodes: https://hackaday.io/project/189216-freeeeg16-alphafreedryelectrodes16x34cm,
inspired by https://www.ncbi.nlm.nih.gov/pmc/articles/PMC9627315/
Comma-Separated Values - 1.79 kB - 04/05/2023 at 13:07
Zip Archive - 2.40 kB - 04/05/2023 at 12:55
Zip Archive - 105.46 kB - 04/05/2023 at 12:54
View all 3 project logs
This project is looking impressive. About a month ago, I was wondering if a higher density BCI solution using pogo pins directly touching the scalp would improve things and bridge the gap between invasive and non-invasive performance.
DoctorDre
Sanpi
Victoria
Central Space Alliance
Yes, delete it Cancel
You are about to report the project "FreeEEG16-alpha1.0 TEST FAILED", please tell us the reason.
