Project log-08012023
A project log for New open source hardware 1U satellite project.
tranvinhquangTRAN.VINH.QUANG • 02/26/2023 at 04:00•0 Comments
Node number 8. The project conducts the design of gcode to process prototypes. The gcode file will be inserted into the machine to create the circuit template. Each machine will need its own design parameter, so this gcode file is calibrated according to that parameter, to ensure feasible machining.
