Reverse-engineering the PCB
A project log for Vintage Effect Reverse-Engineering
Full reverse-engineering of Sochor DRX-85, an obscure Polish digital delay device from 1986.
keri-szafirKeri Szafir • 02/27/2023 at 20:29•0 Comments
DRX85 on a light box, allowing me to see traces on the bottom side. No photography equipment or post-processing here, and since the board is big, it'd be a bit impractical to do it the Big Clive way.
Closeup of a phenolic single-layer PCB. All through hole, no SMD.
