XML/SVG symbols have received some love now. Check the examples if you want to see a nice 7-segment display being used.
We also discovered that the text of some users was being messed up. The reason was traced back to the locale of the user (using comma's instead of decimal dot). This messed up the SVG output causing text to behave very strangely.
As an added bonus, there is also now a splitter between the editor and preview. Hope you like it!
Sven
