Firmware overview
A project log for Paper WiFi
WiFi/BLE-enabled low power e-paper display devboard
albertas-micknasAlbertas Mickėnas • 03/09/2023 at 19:41•0 Comments
Fully functional firmware supporting low power operation is provided and can be found in the github repository.
Since we are using deep sleep, all the action happens in the setup function, only few state bytes are kept in RTC memory that is retained between wakeups:
void setup() {
  Serial.begin(9600);
  Serial.println(String("Hello, is_first_run:") + is_first_run);
  SensorsInit();
  SensorsPowerOn();
  SensorReadings new_readings = SensorsRead();
  if (is_first_run) {
    sensor_readings = new_readings;
  SensorsPowerOff();
  if (is_first_run || sensor_readings != new_readings) {
    DisplayInit();
    NetworkInit();
    DisplayData(new_readings, is_wifi_connected);
    Serial.println(String("is_wifi_configured:") + is_wifi_connected);
    if (is_wifi_connected) {
      MqttSetup();
      MqttPublish(new_readings);
    } else {
      Serial.println("Wifi not connected");
  is_first_run = false;
  DeepSleep(DEEP_SLEEP_TIME);
WifiManager library is used to support WiFi credential provisioning.
GxEPD library is used to access the display.
Examples available:
