CH334 is USB2.0 protocol compliant 4-port USB HUB controller chips, supporting USB2.0 high-speed and full-speed for upstream ports, and USB2.0 high-speed 480Mbps, full-speed 12Mbps and low-speed 1.5Mbps for downstream ports, supporting not only low-cost STT mode (single TT schedules 4 downstream ports in time share), but also supports high performance MTT mode (4 TTs each corresponding to 1 port, concurrent processing). Industrial grade design with streamlined peripherals for use in computer and industrial control machine motherboards, peripherals, embedded systems, etc.
Official website: http://www.wch-ic.com/products/CH334.html
Purchase link on AliExpress: https://www.aliexpress.com/item/1005004916791100.html?spm=a2g0o.store_pc_groupList.8148356.13.e40a7a7cYuUBna&pdp_npi=2%40dis%21USD%21US%20%2412.80%21US%20%2412.16%21%21%21%21%21%40213fa03116781574247821145e1d2e%2112000031396082179%21sh&gatewayAdapt=4itemAdapt
Kenny Tao
Edwin Hwu
Richard Testardi
