The result is not as good as I could imagine however it is perfect for its functionnality <3
- The goods :
- Large screen : 10.3 inches
- everything I wanted plus :
- a full USB port which I can use to make my backup, to put some books, etc.
- The bads :
- a bit thick (but as expected),
- the battery lasts 6 hours (also expected),
- the touchscreen was very glossy. I had to put a mate protection,
- I must turn off the device with physical button because devices like radxa and other raspberry pi consume battery while halted (https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#typical-power-requirements)
- the sdcard is not accessible (although it is possible te remove it and insert it. it's just it is very hard to have access).
I can share the software parts if someone needs it :)
