Quick & Simple Infrared Remote Decoder
When you're testing infrared remotes, sometimes you just want a quick check—no need to plug in USB cables, install drivers, or launch terminal windows. This IR Decoder is all about simplicity and speed.
Why decode remote commands?
Backing up your remote’s commands is a smart move. If your remote becomes lost or stops working, having the command data and device ID lets you reprogram a universal remote easily. It's also useful for learning how your remotes interact with your devices.
Two Modes, One Jumper
Basic Mode: Displays only the essential information.
Advanced Mode: Shows all available data for deeper analysis.
Switching between modes is as easy as installing or removing a jumper.
Easy to Use
Select your desired protocol from the onboard menu, point your remote at the Decoder, and press a button. The data is instantly displayed on the built-in OLED screen—no external tools required.
Supported IR Protocols:
NEC1 (38 kHz)
NEC2 (38 kHz)
REC80 (56 kHz – common for cable boxes)
Sony12 (40 kHz)
RECS80 (38 kHz)
DISH (56 kHz)
RC5 (36 kHz)
RC6 (36 kHz)
- TDC-38 (38 kHz)
Whether you're backing up remote codes, testing signal output, or tinkering with home automation, this Decoder makes it quick and easy.
For more information, please visit:
https://www.tindie.com/products/remotemod/standalone-infrared-decoder/
remotemod328
schlion
trollwookiee
Åke Hedman
Bitmerse LLP
