You can now get your own OPL2 Audio Board at Tindie.com. The board is available both as a kit and in assembled form. Detailed instructions on how to put the kit together can be found in the Github repository that also contains the library software and examples.
The kit is an updated version of my original board including a simple amplifier and a 3.5mm audio jack instead of terminal connectors
