Octopart links to chips in BOM
13 U1, U3 PAL20L8 or better e.g. 22V10 14 U11,U12 27256 15 U14,U15 74ALS573 Transparent latch, 8-bit 16 U2 74LS74 17 U4 74LS32 18 U5 74LS646 Octal bus transceivers and register 19 U6 74ALS00 20 U7 74LS175 21 U8 NS32202 Interrupt Control Unit 22 U9 74LS30 23 U10 74LS04 24 U13 NS32081 Floating-Point Co-processor 25 U16 NS32201 Timing Control Unit 26 U17 NS32016 Processor 27 U18 DP84412 Replace with PAL16R6 or better e.g. 16V8 28 U19 NS32082 29 U20 DP8419 DRAM address multiplexer and refresh row counter 30 U21 74S32 31 U22 74LS08
The PAL chips are no problem, I have original PAL chips and the logic can be ported to modern GAL chips.
Keith
