I've added tech data so you can build your own PD32 or at least the reconstruction of it. There are schematics, PCB layout, two BOMs, 3D rendering images, and Gerber files.
If anyone decides to make their own PD32 using the supplied Gerber files please post here with your results. Especially if any changes are necessary and/or you find improvements.
Would really like to see your results of a PD32 build. Thanks!
Andrew Lynch
