Hi all,
Here we are with our new application which is super cool! Actually it's a bit old but I brought it back for the 1kb challenge. Anyways, lets talk about it.
It is an electronic dice based from random number generator which is also based from LFSR(Lineer Feedback Shift Register)
Random generator genarates two integers between 1-6 to perfom dice values. Than it shows the values on 7 segment displays.
Figure-1You can see schematic circuit at figure-1. It consist of 3 main parts those are Microcontroller(AT89S52), 7 segment displays and their drivers(74HC595) and Dice button to play dice.
Figure-2I have set circuit up on bread board as you can see at figure-2. Also there is isis simulation for the application. You can find it in the github repo.
Application codes written in assembly language. Code size is around 203 bytes which means it's fitted for 1kb challenge! Hooray!
;	Program 	: ElectronicDice.asm				*
;	Author			: Erhan YILMAZ				*
;	Date			: 17-12-2016			  	*
;	Version			: 1.0				  	*
;	Size			: 203 Byte				*
SHIFT_DATA 			EQU 	0X20		; Seri veri yoluna gönderilecek veriyi tutan yazmaç
CHIP_SELECT			EQU 	0X21.0		; Gösterge(74HC595) Seçme biti
RASGELE_SAYI 		EQU 	0X30			; Rasgele sayı değişkeni
ANIMASYON_SAYAC		EQU		0X30		; Animasyon programı sayacı
ZAR_BUTON			EQU 	P1.0		; Zar atma butonu
SCK					EQU		P2.0			; 74HC595 Saat sinyali çıkış pini
SDO					EQU		P2.1   			; 74HC595 Seri veri çıkış pini
CS1					EQU		P2.2			; Gösterge 1 seçme pini
CS2					EQU		P2.3			; Gösterge 2 seçme pini
			ORG 0000H					  	;RESET vektörü adresi
			AJMP BASLA						;BASLA etiketine git
			ORG 0100H
;7 parça gösterge veri tablosu
;	   a
;	|	  | b
; f	|  g  |
; e |	  | c
;	 ----- . dp
;	   d
;				   .gfedcba
; Segment Data = 0bxxxxxxxx
; 7 parça göstergelere gönderilecek olan değerler program hafızadan sabit olarak okunarak göstegelere gönderilir.
SEGMENT_TABLO:     	DB      0X3F,0X06,0X5B,0X4F,0X66,0X6D,0X7D,0X07,0X7F,0X6F,0X77,0X7C,0X39,0X5E,0X79,0X71
ANIMASYON_TABLO:	DB		0X01,0X02,0X04,0X08,0X10,0X20
BASLA:
			CLR 	A				; Akümülatörü temizle
			MOV 	P2,A				; Port2'yi temizle
			MOV 	ANIMASYON_SAYAC,#0X00		; Animasyon sayacını sıfırla
			MOV		TH0,#0X01		; Timer0 reload değerini yükle
			MOV		TL0,#0X01		; Timer0 ilk değerini yükle
			MOV		TMOD,#0XF2		; Timer0 8 bit tekrar yüklemeli(0x01) olarak çalıştırılır.
			SETB	TCON.4				; Timer0 çalıştırılır.
			CLR		CHIP_SELECT		; Başlangıçta Gösterge 1 temizlenir.
			MOV		SHIFT_DATA,#0x00
			ACALL	SHIFT_SEND_BYTE
			SETB	CHIP_SELECT				 	; Başlangıçta Gösterge 2 temizlenir.
LOOP:
			JB 		ZAR_BUTON,LOOP			  	; Butona basılana kadar bekle
			ACALL 	GECIKME						; Buton arkını önlemek için bi süre beklenir.
KAL:
			JB		ZAR_BUTON,ATLA				; Buton bırakılana kadar animasyon programını çalıştır.
			ACALL	ANIMASYON
			AJMP 	KAL
ATLA:
			ACALL	ZAR_AT				   		; Birinci zar değerini üret
			CLR		CHIP_SELECT			   		; Gösterge0'i seç
			ACALL	SEGMENT_GOSTER		   		; Zar değerini Gösterge0'de göster
			ACALL	ZAR_AT						; İkinci zar değerini üret
			SETB	CHIP_SELECT					; Gösterge1'i seç
			ACALL	SEGMENT_GOSTER				; Zar değerini Gösterge1'de göster
			AJMP	LOOP				   		; Sonsuz döngü
;	Bu alt program 1-6 arasında rasgele sayı üretir sonucu Akümülatöre yazar.
ZAR_AT:
			MOV	 	RASGELE_SAYI,TL0			; Rasgele sayı üreteci için Timer0'dan başlangıç değeri al
TEKRAR_URET:
			ACALL	RASGELE_SAYI_URET	   		; Rasgele sayı üret
			MOV		A,RASGELE_SAYI
			ANL		A,#0X0F
			CJNE	A,#0X00,SIFIR_DEGIL    		; Üretilen rasgele sayının alt 4 bitinin sıfır olup olmadığını test et.
 			SJMP	TEKRAR_URET			   		; Sıfırsa başka sayı üret.
SIFIR_DEGIL:
			CLR C
			SUBB	A,#0X07
			JC		BITIR						; Üretilen sayının alt 4 bitinin 6'dan büyük olup olmadığını test et.
			LJMP 	TEKRAR_URET			   		; Büyükse başka sayı üret.
BITIR:
			MOV		A,RASGELE_SAYI
			RET
;	Bu alt program	(A) Akümülatördeki değerin alt 4 bitini (0-F) göstergelere
;	gönderir. CHIP_SELECT bayrağı set edilmişse veri gösterge1'e edilmemişse gösterge0'a gider
SEGMENT_GOSTER:
			ANL		A,#0X0F
			MOV     DPTR,#SEGMENT_TABLO
           	MOVC    A,@A+DPTR
			MOV		SHIFT_DATA,A
			RET
;	Bu alt program	SHIFT_DATA yazmacındaki 8 bit veriyi seri veri yolu üzerinden 74HC595 çiplerine gönderir.
SHIFT_SEND_BYTE:
			MOV 	R0,#0X08					;Sayac değeri olarak 8 yükle
GONDER:
			SETB 	SDO							; Seri veri hattını set et
			JB		SHIFT_DATA.7,A1				; SHIFT_DATA.7 bitini kontrol et
			CLR		SDO							; Sıfır ise seri veri hattını sıfıra çek
A1:			SETB 	SCK							; Saat sinyalini oluştur.
			CLR  	SCK
			MOV		A,SHIFT_DATA				; Diğer biti göndermek için 1 bit sola ötele.
			RL		A
			MOV		SHIFT_DATA,A				; 8 bit yollanana kadar devam et.
			DJNZ 	R0,GONDER
			JB		CHIP_SELECT,A2				; Gösterge 1 seçiliyse
			SETB	CS1							; 1. 74HC595 latch edilir.
			CLR		CS1
A2:
			JNB		CHIP_SELECT,A3				; Gösterge 2 seçiliyse
			SETB	CS2							; 2. 74HC595 latch edilir.
			CLR		CS2
A3:
			RET
;	Bu alt program LFSR(Lineer Feedback Shift Register) temelli 8bit rasgele sayı üretir.(alıntıdır.)
RASGELE_SAYI_URET:
			CLR 	C
			MOV		A,RASGELE_SAYI
			RRC		A
			JNC		SON1
			XRL		A,#0XB4
SON1:
			MOV		RASGELE_SAYI,A
			RET
;	Bu alt program göstergelerde yürüyen segment efekti yapar.
ANIMASYON:
			MOV     DPTR,#ANIMASYON_TABLO
			MOV		A,ANIMASYON_SAYAC
           	MOVC    A,@A+DPTR
			CLR		CHIP_SELECT
			MOV		SHIFT_DATA,A
			SETB	CHIP_SELECT
			MOV		SHIFT_DATA,A
			ACALL	GECIKME
			INC		ANIMASYON_SAYAC
			CLR		C
			SUBB	A,#0x06
			JC		SON2
			CLR		A
			MOV		ANIMASYON_SAYAC,A
SON2:
			RET
;	Bu alt program gecikme sağlamak için kullanılır. (alıntıdır)
GECIKME:
			MOV 	R1,#0X04
			MOV 	R2,#0X80
BEKLE:
			DJNZ 	R1,BEKLE
			DJNZ 	R2,BEKLE
			RET
END
As you can see below it is written in asm. Unfortunately comments are in Turkish. But code is clean and you can understand it easily.
And finally here application video. You can watch and see how much it is cool!
You can file all files in the github repo of ElectronicDice.
As result as It is a nice circuit entertaiment aimed. You can make it before xmas for your funny games! I hope it makes you inspired!
See you on next post!
Cheers..
