Hackaday.io Hackaday.io
Sign up Log in
Fotos Mini, A Compact Digital Picture Frame
Fotos Mini, A Compact Digital Picture Frame for Synology NAS. Built on a 4.3" display with USB Type-C port for charging and image transfer.
royroy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.8k views
0 comments
7 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 79
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
4.8k
0
7
9
Team (1)
  • royroy
Join this project's team
  • Twitch
hardware
ongoing project
Software
This project was created on 03/12/2023 and last updated 3 years ago.
Description
Development on the Fotos Mini began in March 2021 and was publicly released on reddit at /r/Synology on October 2023.
I included the features and some technical details as part of the launch post https://www.reddit.com/r/synology/comments/16xx6bv/my_small_contribution_to_synology_a_compact/.
Email me with questions at roy.moran@icloud.com. I’ll make sure the project works for you over time.
Project Logs
Collapse
  • Identifying LCD Flicker on Unprogrammed STM32 Chip
    roy • 01/19/2024 at 18:00 • 0 comments
  • Python Application for Generating Device Serial on New Orders
    roy • 11/05/2023 at 02:44 • 0 comments
  • Fotos Mini Initial Setup Guide
    roy • 11/01/2023 at 02:11 • 0 comments
  • Fit Assembly into Enclosure
    roy • 10/30/2023 at 14:15 • 0 comments
  • Fixed Bug for Improved Exif Parsing
    roy • 10/28/2023 at 20:28 • 0 comments
  • Recovering Failed Assembly
    roy • 10/26/2023 at 16:47 • 0 comments
  • Assembly Mistakes with Failed Board, And Some Improvements
    roy • 10/25/2023 at 13:14 • 0 comments
  • Assembly, Update Reflow Soldering Process Now with Hot Plate + Hot Air Gun
    roy • 10/21/2023 at 15:26 • 0 comments
  • Assembly, USB Orientation Detection Fix, Documenting Assembly and Problems
    roy • 10/20/2023 at 12:07 • 0 comments
  • Assembly, Completing Assembly
    roy • 10/18/2023 at 15:32 • 0 comments
View all 79 project logs
Log In/Sign up to comment
Sign up with Github
OR
A low cost USB dev board with CH554, RGB LED, AHT21 sensor, and open-source firmware—perfect for MIDI, IoT, and USB hacking.
Project Owner Contributor
Johnny554 IoT development board
vincentVincent
The World's Smallest SAMD21 Development Board
Nimbug M0
ella-jamesonElla Jameson
Function Keys for a Scope! Embedded USB host provides access to key functions buried too many menus deep
Scope Keys
chris-strattonChris Stratton
Pure Thermal 1 is the next development platform for the Flir Lepton. Fusing the powerful STM32 with the Lepton
Pure Thermal 1 Development Board
pure-engineeringPure Engineering
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Fotos Mini, A Compact Digital Picture Frame", please tell us the reason.
Send message
Remove Member
