• 1
    Design sketch
    This stairs use to connect first to second floor, only one way, so I take around the building and make a sketch for the first design.
    Of course, I need to design in 3d view, I want to see every angle of stairs. For this, I use SketchUp on web.
  • 2
    Design details
    Let's make it more clearly. All details have designed. With this drawing, I can calculate how much materials I need.
  • 3
    Construction
    First, I've made main bearing structure. Most of herringbone stairs use standing pillar to support stairs, for me, it's not pretty at all, I want the steps to fit into the main load-bearing structure, less is more.
    I've weld main structure first, then use truckle to pull it up in position. This is most heavily job that i have to do, I tight the structure with rope and rotate the truckle. Finally here:
    Keep finish main load-bearing structure left. Then welding each step on ground then bring it up like image below, step by step.
