Hackaday.io Hackaday.io
Sign up Log in
Balancing Trike Robot
8 Axis Balancing Robot to put the Real in Mixed Reality.
sean-cainSean Cain
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
255 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
372
0
255
0
Team (1)
  • sean-cainSean Cain
Join this project's team
shelved project
ROBOT balancing humanoid AR VR rpg
This project was created on 03/16/2023 and last updated 3 years ago.
Description
This robot is a variation of my other AR/VR Gaming Robot project. This "Trike" balances on 2 wheels at the base of it's legs, with a third wheel at the top for friction free steadying against the wall or floor.
The tracking on this robot mostly only tracks the pelvis, to which you can pin any virtual
component of your character you like. Having played with a ton of tracking techs, I like face tracking the best.
I think it will be easier to program then a legged robot. It uses from 4 to 8 motors, and I expect it to weigh about 15 lbs. I'm looking forward to seeing what kind of mobility I can get in a mini obstacle course.
Project Logs
Collapse
  • No Longer Working on this
    Sean Cain • 02/06/2024 at 22:22 • 0 comments
    I just wanted to let anyone that is following this project know that I don't intend on continuing with this project. Mostly it is because I want to focus my attention on the other Machine.
  • Concept Description
    Sean Cain • 03/16/2023 at 00:47 • 0 comments
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
A chatgpt powered animatronic robot that translates languages
Project Owner Contributor
RobotGPT - An Animatronic Multilingual Robot
swaleh-owaisSwaleh Owais
robots that can climb anything even climb on your ceiling
project robot 2.0
ansaadjansaadj
Typhoon is a second generation sumo robot I have built for the recent IEEE sumo robot competition at my university.
Project Typhoon
augustinejinuaugustinejinu
Drawing Robot with Live Streaming and Automated Paper Feed
ArtInCode
maksim-surguyMaksim Surguy
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Balancing Trike Robot", please tell us the reason.
Send message
Remove Member
