Raspberry Pi camera flash
A rather powerful flash for you RPi Camera
The board is designed around the Ti TPS61169 WLED driver. The drivers are connected to the hardware PWM signals of the RPi. Keep in mind that you can't keep the LEDs on for a long time due to almost non-existant heat dissipation capacity of the PCB. The camera can be mounted in the center of the board. If you're using the default 11mm spacers you can fit the camera in the center of the board when folding the cable thightly.
Jacob MacLeod wrote 10/01/2019 at 08:52 • point
Nice! Are you planning to release the gerber files for the pcb?
